Lubrication of 2004 Dodge Neon
2.2K views 2 replies 2 participants last post by  rrcat4me
#1 ·
Can you lubricate the front end of a 2004 Neon SE? I have not seen any grease fittings anywhere on this vehicle. Everything is starting to squeak really bad.
#2 ·
Yes you can.
I just got done replacing both tie rod ends on my neon, the stock tie rod ends didn't have a grease fitting but the ones i purchased for it did. After i put the wheels back on and did an eyeball alignment, I noticed on the underside of the brake discs there are grease fittings pointing directly down, mine were dry as a bone, but they are actually very visible if you have a good eye.
