Engine Code P0740? Anybody else getting this?
18K views 10 replies 5 participants last post by  spidertb
#1 · (Edited)
Hey guys
I have an 2009 SLT 4X4 Hemi and recently when I tow my UTV I get the engine light and code P0740. Anybody else getting this?
I took it to the shop and they have flushed the Transmission. Is that a legit fix?
Any help on this would be great.
Thanks
#2 ·
Engine Code 740. Anybody else getting this?
Per the Service Manual the P0740 code is for Torque Converter Clutch (TCC) is out of range. Possible causes:
Related DTC P0750 present
L/R-TCC Solenoid
TCC Switch valve stuck
TCC Regulator valve stuck
Input shaft seal ring cut
Torque converter and/or internal transmission
Check if your repair facility has access to a Service Manual which will provide further details on troubleshooting issue.
Save
#3 ·
L/R-TCC Solenoid
Thanks for the reply Dodge.
As far as I know the shop does have the manuals and decided to try the flush before going to the TCC and or solenoid.
No other codes were set.
#5 ·
Please keep up posted.
Save
#6 ·
Are you the original owner of the truck?, you have LIFETIME warranty on the powertrain if you are...also those few that I know that had that code needed clutch packs or converter...I know it is too soon....
Save
#9 ·
Yes I know......not in Canada.....but the code is still the same
Save
#11 ·
Well $1800.00 later the torque converter and pump replaced and no code.
Noticeable change just in regular driving.
Dodge really needs to look at beefing up these transmissions or at least the components.
