99 Durango - 5.2L - 97,000 miles. Not shifting into O/D.
Started out occasionally not shifting into O/D. Changed filter & fluid, no change. Pan was clean, nothing on the magnet, oil was still red too. Now the "Check Engine" light is on and it doesn't go into OD at all. The local transmission shop put the magic box on and it showed the computer output was saying 4th gear, but the solenoid always said 3rd. He said if the tranny was shot, there would have been a bunch of junk in the pan when I took it off a couple of months ago, so he said it's probably just the solenoid. About 3 hrs labor and about $200 for the solenoid?
I usually try to do all my own work. Ball joints, air plenum, etc.. does anybody have any inside pictures of where this solenoid is, or should I swallow my pride and let the pro's handle it?
