i have water leaking into my truck in the back driver side seat has anyone had this problem i cant find where its comeing from its all wet under the seat. please help and will warrenty cover this.
i checked by the window and i did not notice water but i am going to spray it down and check again i just wanted to see if anyone else has had the same problem
Check the 3rd brake light seal. It will follow the inside of the cab and soak the floor. And thier are 2 seams that run under the rear window where the cab corners seam to the panel under the rear window, Those seams will split and let water in.
My Gen III has not leaked, but my Gen II sure did. I just took the CHMSL out and ran a bead of silicone around the rim. Worked like a charm. Sure was annoying to have to track down the leak.
thanks guys i have not had time to look at it again but i will let you no when i figure it out
Related Threads
DodgeTalk Forum
posts
4.7M
members
305K
Since
2002
