i put a 200amp alt in a year ago. was geting ready for the ele fans and the underdrive pulley kit.
some have reported that a belt is not possible in 7 rib for the underdrives. i could understand that! more selection in the 6 rib version.
this could get confusing! i need a 94.0" for the underdrive kit, to route it CORRECTLY. i could have that belt in a 6 rib version only. the 7s jump from 95.0" down to 92.3". im inbetween sizes.
so, i routed the belt diff than the diagram. i run from the crank on the right to the power steering. on the left the belt runs from the crank to water pump to tensioner! i'm running the 88.5" belt. have no problems. auto parts store says the ps pump may slip since the angles are less severe around the pulley. travel around the ps pulley is just alittle less. so far so good, and a 7rib. i think "dodgepickup" had this trouble.
my charging amps are just fine and i have so drop outs in power when the accessories come on. this was not planed out by the pulley manufacterer and is not a typical install. PITA!
