Can you? Yes. When synthetic was first introduced it got a bad rap because people's engines started leaking. If you have any kind of old seals or gaskets the synthetic will find leak points. If it's fresh re-gasket or rebuild then you should be good. Any old/older seals you have the synthetic will find them and leak.
