Spark plugs/cap and rotor??
1.8K views 20 replies 15 participants last post by  DodgeFreak
#1 ·
I am upgrading my plugs, wires, etc... on my 96 Ram 318. I am installing an MSD Blaster Coil along with MSD 8.5mm wires. I am looking at going with a MOPAR performance cap and rotor and Bosch Platinum plugs. Any other good combinations to think about? :rck:
#2 ·
Just make sure the cap and rotor have brass tips. I've never used bosch plugs and don't really know a whole lot about them, but if you haven't bought the plugs yet I would really suggest thinking about getting either Autolite 3923's or NGK 2262's. Throughout tons of posts and research over the years on these forums I've found those 2 plugs to be used and recommended the most and you really can't go wrong with either one. I've got the NGK's in my '02 and I also ran them in my '97 318. Plus the autolites are really inexpensive and can be found everywhere, including wal-mart! Yes, wal-mart, but that has no bearing on the quality of those plugs.
Overrall you've got a pretty good combination and the MSD wires are pretty good.
Save
#3 ·
Go with the NGK, the Autolites suck!
You need to check out the IAT link in my signature!
Save
#4 ·
Any prey tell, why do Autolites suck? :WHT:
Save
#5 ·
Yeah, why? You're actually the first person I've heard say they suck.
Save
#8 ·
Stay away from Bosch platinum plugs!!!!!!!
I have had nothing but trouble with these plugs in any Mopar product. I have had more customer driveability problems with these than every other plug combined.
I always recommend Champion or NGK depending on application. Autolites will sometimes seize when used with aluminium heads and left in a little too long.
#9 ·
I've got the bosh plats in mine now. No problems other than a slightly rough idle, but i think the wire for cyl 6 has the crappy carbon shiz in it. I changed out the cap and rotor, and the pin on the cap for 6 was all gunked. Too bad I can get a good set of wires at the moment. :(
Save
#10 ·
I got the Autolite 3924's. Not sure about the difference between them and the 3923's. I went with the Echlin cap and rotor. Have not installed them yet but hopefully the results will be good. Still time to change my mind and go with the NGK's.
#12 ·
Dodgevanman said:
The 3923's are a "colder" plug and are supposed to give a slight power boost.
You will want a cooler plug if you are having detonation problems as this will help dissipate heat away from the plug quicker eliminating one of the possible hot spots in a cylinder than can cause detonation. Performance will not differ with heat ranges.
My 2¢:)
#14 ·
phatman,
you mentioned you couldn't find a decent set of plug wires, i grabbed a set from Summit about 4,000mls ago and they've been doing great... actually i bought the set {cap rotor and 8mm plug wires} for $55... not to bad! and chances are if its time for wires its time for cap and rotor
#15 ·
Plugs, rotor and cap
What is the reommended plug wire replacement for the 2nd gen, 5.2?
Good point on the brass tips on the rotor and cap, I will check mine before I install the d-mm thing (so hard to get to) I think I might need a surf board to lay across from one fender to the other to lay on to reach back there :rck:
Save
#16 ·
get a stepstool and work from the sides, or sit on the passenger's side fender one leg in the e-bay, the other out. im 6'7" and that helped abunch
Save
#17 ·
I found the best way to change the cap and rotor was from kneeling onthe front bumper and working from there. I went with the 3923's and noticed a decent gas mileage boost when added with the rest of the items from my tuneup. Brass Contact cap and rotor from napa, Belkin wires kit, cleaned the K&N Dropin, and of course for xtra HP, I cleaned the engine. LOL
Save
#19 ·
just take off the air hat and go to town, kneeling on the bumber with a towel was comfortable enough for me, and don't cross wires, oh btw way this is funny, a clerk at pep boys said "those trucks dont have a cap and rotor distributor, they have smelters"
Save
#20 ·
do what? :huh:
Save
#21 ·
Race I have the same set up you are going with and have the NGKs. I have not had a problem with mine at all. If you already have the Autolites then you may as well stay with them.
Save
