In the front wheel wells you'll see a panel. Remove the panel. That gives you access to the back end of a screw at the top of the headlight assembly. This screw is permanently attached to the top of the headlight assembly. I forget wat size wrench u need but its simple to remove the nut holding that screw in place. Just feel around with your hand. Then from the front of the truck under the headlight assembly are 2 screws you need to remove. Once you remove the 2 front screws and the one rear nut, carefully pry out the headlight assembly. It's stuck in there using a ball and joint connection. So just pull hard enough to pop the ball out of its socket. If pulling doesn't work, and for me it didn't, take a flathead screwdriver (wrap the flathead with a towel so you dont scratch the paint) and wedge it in between the top of he headlight assembly and the frame of the truck and use it to wedge out the headlight. Al in all, it takes about 5 minutes to remove the screws, nut and headlight assembly for just one side of the truck. Just remember not to pull so hard that you pull out all your cables if the assembly pops loose easily. I know it seems like a lot of instructions, but trust me, its so easy. I did it without removing the front wheels but some people do remove the wheels just to make it even easier to reach everything.
