Flex a lite 183 questions ???
2.3K views 18 replies 8 participants last post by  HEMI450HP
#1 ·
Im sorry if this has been in discussion but im thinking of buying one of these soon. i just need to verify its worth my money before going through with it. First i have the 4.7 and i called flex a lite to see if it would work they said it should as long as my coolant/washer fluid reservoir was a single unit. Next will it actually help hp/torque? Does it come complete with everything needed for install and is a 180 t stat needed? Lastly has anyone bought the setup from amazon for around 250.00?
Save
#2 ·
No, the $250 would be just the e-fan and maybe it might come with a controller. You can do the shroud delete but I'm not sure if Moe's Performance sell them any more. A number of members have found bottles to replace the factory ones and made their own delete kit. As for the 180 t-stat, you only need that if you plan to use a programmer tuner on the engine.
Save
#3 ·
So i contacted amazon and they said they get the 183 fan assembly from flex a lite and that i will receive it exactly the same as if i ordered it from flex a lite. she said if there is any issues they will pay for return shipping plus full refund. so im gonna try it friday and when i receive it i will let everyone know what happens. but between now and friday if anyone else has any suggestions or dislikes on the 183 please let me know.
thanks
Save
#4 ·
I have the 180 that fits inside the stock shroud. The kit came with a controller, wire and terminals. Simple install and it all still looks stock. As far as performance I've had no issues. I have it wired to the battery so it still cycles on and off after the truck is shut down. Been a few months and no issues. As far as the butt dyno I haven't noticed much but im sure its freeing up some hp. I have a 180 tstat and the temp gauge never rises above 1/4. My opinion is thtlat its a worthwhile investment.
Good luck
Save
#5 ·
The Black Magic Xtreme Series e-fan is one of the most favored fan since Dodge doesn't make the Viper Truck fan any more. The 4Gen folks can use the Ram V6 fan and it's just a simple plug-n-play but it doesn't work with the 3Gen trucks. You get it setup, you'll like how quite and how much better the engine runs.
Save
#6 ·
I have it an I love it so far cant tell a difference tho cause i put it in about 3 weeks after i did my gears, but it cleaned up the engine bay tho an thats what i wanted. On the instructions it says it fits the 3.7, 4.7 an 5.7 liter motors
Save
#11 ·
So i put the 183 fan in my amazon cart for 250.00ish was gonna order tomorrow then i got a notice from amazon stating that the price went up to about 330.00ish what a bunch of BS. I just wonder since their price jumped that much did other companies raise their price as well? Who knows, just my luck.
Save
#17 ·
Like mentioned, the fan does come in its own shroud, and includes the brackets needed to mount the factory coolant/washer fluid tank. It also comes with wiring and an adjustable temp controller that allows you to set the fan to come on anywhere between 160-240*. I have 6 of these in stock right now, so I can get this out for you today if the order is put in my 3pm. Let me know if you have any questions.
Matt
#16 ·
This is on my list. I wanted to do in last winter, but the timing wasn't right. Maybe this year I can do it over thanksgiving or Christmas brake. I am just concerned with the whole wiring thing and removing the stock fan assembly. I would toss the shroud to free up some space under the hood.
As for ordering from Moes, thats what I will be doing. I want to get the Sharadon Stage 3 VB and he has the best price around, plus I can keep my OEM one incase I ever want to swap it back.
Save
