Drop Kits (ATTN: Slammed1)
1.5K views 11 replies 6 participants last post by  SiZzOuRcE
#1 ·
Slammed1,
I have no idea what Im doing when it comes to suspension. My question is, what do I need to drop my rear to stay level with the front and what if I would like to drop the front 2 inches as well. I've looked through your site also, but I don't understand anything.
Thanks, Ill be PMing you about something else as well.
Save
#2 ·
if you want to go with a 2 inch drop in the front and keep the back level, you'll need a 2/4.
to level the back with the front, you can either lower the back or raise the front. Lowering the back can be accomplished by removing the overload leaf and installing a shorter drop shackel. raising the front by a coil spacer. lowering the back looks better if you plan on keeping a stock tire heighth and is probably easier.
send brian a pm. if you want to go 2/4, you've got a choice between springs or spindles in the front and a flip kit or drop leafs in the rear. New shocks should be installed to produce the best ride quality.
Save
#3 ·
How much and what product do I need to buy to just level it. It seems that the 2/4 seems to be alot of work and probably alot of money as well.
Save
#4 ·
To just level it, you would need a set of drop shackles for the rear. These will lower the rear by ~1.5". This will get you pretty close to level. You can also remove the overload springs to get another ~5/8"
Save
#5 ·
Or you can do what I did.Get drop shackles,remove the overload spring and move your middle spring to the top,get shock extensions,and front coils springs and bump stops and your set.190 is all I spent and I got a 2/4 drop.
Save
#6 ·
Here's mine with just a set of Ground Force rear shackles installed.
My Hotchkis 2/4 TVS kit has been ordered.
Save
#7 ·
Is it hard to install the drop shackles? Can I do it myself?
Save
#8 ·
And is this what I need to purchase to level?
BellTech 2" drop shackles (factory bushing style....NON-poly)
---$85.00 shipped
Save
#9 ·
Took me 30 min to install my drop shackles. Floor jack, stands, ratchet, and lube is all you need.
Save
#10 ·
not hard at all. but it will not make it PERFECTLY level.
Save
#11 ·
slammed1 has some different shackles now that are better and cheaper.
Save
#12 ·
I pmed in yesterday, so maybe he can help me out with deciding.
Save
