Code p2323
15K views 10 replies 4 participants last post by  HEMI450HP
#1 ·
Has anyone seen this code before. I called Dodge, and the guy told me he had no idea.....I cleared it with my Superchips, but I would still like to know what it means...
Save
#2 ·
Come on guys, nobody can help me on this one???
Save
#3 ·
P2323 is Ignition Coil No. 8 Secondary Circuit Insufficient Ionization. Possible causes are ASD relay Output Circuit, Coil on Plug Resistance, Ignition Coil, Coil Control Circuit Open, Coil Control Circuit Shorted to Ground or PCM problem
Save
#5 ·
No problems at all. I was on my way to work, and it came on. It has thrown this code, and about 3 months ago it threw a p2308, and about a month before that, it threw a p2302. I think it may need a few coil packs, but it never misfires.
Save
#8 ·
barky24 said:
Since I haven't had a coil pack go bad, what are the symptoms you encounter?
My truck ran a little rough, but it wasnt as bad as I thought it would be with a bad coil. Only reason I knew was because of the code, but it was a different code than what slowhemi threw.
Luckily, I bought an extra set of coilpacks a while back and had 1 with me at the time. I put the new coilpack in, the code went away, and the truck has run fine ever since.
#10 ·
I wonder if it has anything to do with the superchips.... It never did this before. Also, if a connection was loose, wouldn't it misfire?
Save
