Anyone done a 99 to 2000-2001 brake swap on 1500 ram 4x4
6.1K views 6 replies 3 participants last post by  99sliverram
#1 ·
Has anyone ever switched their brakes on on their single piston caliper 94-99 Ram 1500 4x4 over to the bigger rotor 2 piston caliper set up off the 2000-2001 Ram 1500 4x4? My 99 is getting due for a brake job and even with slotted/cross drilled rotor and ebc street pads. It still doesn't stop as well as my old 2000 did with the same parts.
Save
Discussion starter · #3 ·
No I still have the factory rear cylinders. What year chevy dually cylinders are the best to use?
As far as the front brakes. Unless the axle was changed in 2000-2001 the caliper brackets should bolt on from the 2000-2001. And just buy new calipers/pads.
Save
Discussion starter · #6 ·
OK, I'll ask the stupid question LOL. Where to look to see if I have bendix or bosch brakes on the truck?
Save
Discussion starter · #7 ·
Disregard. I figured it out. It's bosch.
Save
