5W20 oil in Texas
1.8K views 18 replies 14 participants last post by  jmgak47
#1 · (Edited)
Guys,
I have a 2010 Dodge Ram Sport with the Hemi......and I'm changing the oil this weekend.
Those of you living in Texas, are you sticking with 5W20 weight oil ?
Seems super thin for Texas heat.
Let me know, thanks.
#2 ·
I am changing to 0W30 for this summer. I tow a lot during the hot summer months and the 20 weight oil is thinner than water when it get hot. The MDS system supposedly requires 5W20 to operate, but I have mine disabled so that's not a problem.
#3 ·
Think about this for a bit.
These engines, transmissions, are water cooled, as determined by the thermostat.
Engines in Texas, really don't operate under any different parameters than they do in Wisconsin.......
Save
#4 ·
I beg to differ. Have you ever towed a heavy load on a 110 degree summer day? I have seen oil temps as high as 235 degrees while towing in the summer. Towing the same load in spring or fall the oil is easily 15-20 degrees cooler.
Remember that the radiator that that cools the water to cool the engine is cooled by air. 110 degree air passing through the radiator core is a lot different than 80 degree air.
#5 ·
You completely missed my point - a vehicle pulling a trailer in Wisconsin, at 100 degree heat, is no different than the same thing in Texas.
Yes, it does get to 110 in Wisconsin, but I'll bet you never see -40 in Texas...
Save
#10 ·
I agree, we are over 80* for much of the year, ever seen 5w20 when it is 105*F outside and you change the oil on a truck that is being used. It drains out faster than water, no viscosity to it at all.
I run a 170*F thermostat, 1 ton Hemi Radiator, and a Flex-a-lite Efan with a variable speed control. Truck never runs hotter than 180*F, even taking a beating while towing.
#6 ·
"Remember that the radiator that that cools the water to cool the engine is cooled by air. 110 degree air passing through the radiator core is a lot different than 80 degree air."
Actually, not that different - you are only talking about a 30 degree differential, vs 195 operating degrees. And, the cooling system is designed for this (and more) differential.
Save
#7 ·
and to add, i think you would have a hard time with warranty claim if you do have an engine malfunction and you were not running the 5/20 oil. just saying, why put yourself into that possibility if you are still in warranty (either lifetime or the 100K mile)
#8 ·
i would stick with 5w-20 as recommended by the manufacturer and just run a high quality synthetic oil
Save
#12 ·
5W20 here as well I have ran that since I bought the truck and I have been through 3 hot a** summers, No problems. Now if your towing a lot then it may be different but just normal driving and even long road trips I wold just stick with the 5W20
Save
#14 ·
No mds here and my RAM also takes 5w20
Save
#15 ·
Texas,Georga, Key West, Maine its all the same. 5w20. I bet in heat of the summer theres not a degree of difference in oil temp from state to state. Texas is bigger.
Save
#17 ·
If its a HEMI with MDS in a 1500 it calls for ONLY 5w20.
Save
#19 ·
5w-20 here and wouldn't run any other weight. They are designed for it. If your worried about heat install a 180* T-Stat.
Save
