5.7 low oil pressure
5.5K views 13 replies 10 participants last post by  Jdub2010
#1 ·
So the check engine light came on on my 08 1500 hemi with 68k miles on it and the code that came up said that it had low oil pressure. I took it to jiffy lube and the guy said that they it was about half a quart low and there was no apparent leak. I had just gotten my oil changed at the same place less than 2 months ago and he said that it might have been a wrong filter and that it wasnt a big deal so they changed the oil and filter and said to bring it back if it comes back on. well thats reassuring! has anyone else had this problem or have any ideas what it could be?
Save
#2 ·
If I'm not mistaken starting in 08 the oil filter threads changed size from previous 02-07 filters. Maybe they screwed on the wrong filter and some oil leaked out. Regardless, reason number 672 not to ever trust drive thru jiffy lube places.
Save
#6 ·
What he said. Never, but NEVER even let Jiffy Lube clean the windshield. 1/2 a quart wouldn't cause a serious low-pressure situation. Good chance they didn't use the proper oil (or didn't change it at all).
#3 ·
Upadte after further research, In 08 Chrysler switched from a 3/4" SAE thread filter to a M22 X1.5 thread filter.* Not sure if that is the problem or not but good info just the same.
Save
#4 ·
definitely nice to know! thanks Scott!
Save
#12 ·
Big time.
There really should be a PSA on those drive through oil change places..
Save
#7 ·
2008- Up Ram 4.7L Oil Filter
Replacement Cross for the MOPAR MO-899:
AC-Delco AC084
AC-Delco PF 1250
AC-Delco PF 26
AC-Delco PF1250
AC-Delco PF1250CL
AC-Delco PF1250FCL
AC-Delco PF26
ALLIANCE ABP/N10G-LF3681
AMSOIL ASF11
AMSOIL EAO11
ATLAS F-20
AUTOEDGE AL2
Autolite for Oil Filters AL2
AUTOPAR FE336
Baldwin B329
BIG A 92372
Bosch 0986AF1172
Bosch 3410
Bosch 72212
CAM2 C4651
Canadian Tire 17-1738-2
CARCARE IOF2
CARQUEST 84899
CARQUEST 85372
CARQUEST B4651
CASITE CF110
CASTROL CAS2
CENEX CO820
ChampLab PH26
ChampLab PH500
ChampLab PH820
CHRYSLER 4884899AB
CHRYSLER 5038041AA
CITGO C4651
CROSLAND 2010
DEFENSE DL2
DELPHI FX1008
DENSO 150-1014
DEUTSCH D407
Donaldson P550965
Econo Lube L24651
EVERGARD E4651
Filters Incorporated OF2
FIRESTONE TF-4651
FIRESTONE TF4651
FLAG C-2
Fleetguard LF16002
Fleetguard LF16214
Fleetguard LF3681
Flying F PH2AZ
Fram PH10575
Fram PH2
FSA C1908
GONHER GP68
GOODYEAR L4651
GRAND PRIX PH820
Grease Monkey GM24651
Grease Monkey GM4651
Group 7 V4651
HASTINGS LF110
HASTINGS LF612
HAVOLINE T-36
HENGST H10W18
JIFFY LUBE HL2
JIFFY LUBE JL4651
JIFFY LUBE L24651
K & N HP-2010
KENDALL K29
KRALINATOR L320
LEE LF-820
LUBER-FINER PH26
LUBER-FINER PH820
Magneti Marelli 1AMFL00006
Mann Filter ML 1006
Mann Filter ML 1049
Mann Filter W920/16
Mechanics Circle MOF 2
MERCURY 35-877761K01
MICROGARD MGL2
MIGHTY M4651
MILEGUARD MO2
MOBIL M1-210
MOBIL MO4651
MOPAR FE00336
MOPAR MO-899
Motor Trend ML2
MOTORCRAFT FL 820
MOTORCRAFT FL 820S
NAPA 1372
NAPA 7899
Parts Master 61372
Parts Master 67899
Parts Plus PH820
PENNZOIL PZ-42
PERFORMAX PO-42
PHILLIPS 66 PO1372
POWER FLO SL24651
PRO/GAUGE PGO-4651
PRO-TEC 159
PROMOTIVE PH2500
PRONTO PO-2
Purolator L22500
Purolator L22500S
Purolator L24651
Quaker State QS2
ROCKHILL 61372
ROVER 4137784
Ryco Z516
Sakura C1922
SECURITY SO-820
SERVICE 1 OF4651
SERVICE PRO M4651
SHELL SH36
SILVERLINE 21372
STP S2
SUNOCO O-35
SUPERTECH ST2
TRUST PH820
UNOCAL PF820
VALVOLINE VO105
VALVOLINE VO47
WALMI WS-2
WARNER PH820
Wesfil WZ516
Wix 51372
Wix 57502
Wix 57899
(Copied from the Bob the Oil Guy web site - 10/2013)
:gr_patrio
Save
#8 ·
My 05 Ram quad cab Daytona (36,000 Miles) was giving me a low oil pressure code and I found out my battery was going out. changed battery, cleared it and never had a problem again, that was 1500 miles ago.:rck:
#9 ·
This is exactly the reason I change my own oil.
Save
#11 ·
You got some good advice but I will tell you whats actually wrong. Half a quart low will not cause a drop in oil pressure. The previous filter that was used until 06 will not scew onto your oil filter adapter so that isn't possible. Wrong oil will set a different code "incorrect engine oil type." Your problem can be solved with a flash update to your pcm. Most dealerships will flash it for around $100. Hope this helps.
#13 ·
With my new Fumoto valve, I can change my oil and filter in about 10 minutes now.
Save
