I have a 99 1500 sport, just recently I put my truck into 4wd and going down a paved road I noticed that I have a shake, or vibration, sort of like driving over a washboard. Would this be my ujoints or something serious.
Read your owners manual!For starters 4x4 is not designed for hard paved surfaces.
You have electronic 4wd?I guess I should have given more info. We had a snow storm the other day, hence driving on the road in 4wd, felt a vibration thought it was from the bad plow job, also went hunting used 4wd down snow covered dirt road. To much snow and bumps on dirt road to feel anything. The only reason I was in 4wd on clear pavement was to verify weather the shake/vibrations was from the the snow and bad plowing from the city or my truck.
The 4wd works great just has the bad vibe. The tire wear is equal and even.
I checked the transfer case drive shaft there is no play in the ujoint and it turns freely.
The pinion is tight with no play in it either.
I do have a lift, diesel coils and 5 inch leveling kit from top gun customz, giving it an level 8 inches of lift and also a 3 inch body lift.
The angle of the front drive shaft is not to much for the ujoint.
I checked the vacuum lines completely and they are good.(obviously because the 4wd is working correctly but checked anyway)
The truck goes down the road straight without holding wheel.
I will jack it up and see if I can feel anything in the axle joints.
