1 - 20 of 21 Posts
I have a 99 Ram 1500 5.2l, with the mods listed in my signiture. I've been reading up on some mods to get better mileage, and one of the recommended mods is the fast man TB... I also read that it seems trottle body spacers really don't do anything at all, and may even hurt performance, is that true? I have a PowerRaid spacer on my truck that came with it, so I never thought about taking it off, but I figured if I get a new TB should I ditch the spacer while I have everything apart? I freakin hate the whistle it makes, it always makes me think I have a vacuum leak, so if it does absolutely nothing for my power, or gas mileage I might as well take it off and sell it to recoup some of the cash for the TB... What do you guys think?
EPA's Worst Nightmare
Get rid of the spacer, there junk. If I were you I would upgrade the exhaust next. Hi-flow cat (or remove, but being an OBDII there would be problems if removed) also a performance muffler. You could also get some headers. Headers didn't do anything for my truck, but I've heard a lot of good things from other people with V8's.
If you go to the fastman website they have a mod so you can ditch the exhaust and not get any check engines lights.
4x4, Straight pipe roar!
and post some pics of that beast! Looks good from your avatar. :cool:
Discussion Starter #5 (Edited)
I forgot to mention that I have 3" exhaust from the cat back, with a DynoMax muffler. I could use a high flow cat though, any recommended brands? I'm probably due for a new 02 sensor also.
So I guess I'll be investing in a high flow throttle body next paycheck, and ditching the spacer on ebay. Thanks for the advice guys!
Also, I've attached some pics of my truck. I'll probably upload them to my user garage eventually.
magnaflow. Me and many others have used them and they're great. Sounds way better than stock. Got mine for 85 bucks off ebay and a shop cut my old one out and welded in new one for 60.
Discussion Starter #7
I'll deffinitely look into that in the future... I did some research and learned that the JET chip is a piece of crap, so I took it out, and slapped it on ebay... I'll probably get a superchip someday. I guess I forgot to upload the pics before, so they are there now, check it out.
nice rig! Whats the lift and brand?
Discussion Starter #9
No clue what the brand is, but it looks to be about a 4"lift... It came on the truck... All the shocks are Rancho, that's all I know.
******* SPACESTATION
once you get the throttle body and magnaflow setup, get a B&G flash.
more gains than any chip or programmer, will also remove torque management, and cost about the same ($350).
Discussion Starter #11
a B&G flash, eh? What exactly is that, and where can I get one? What is the torque management? I'm not familiar with that...
you can read about the flash here http://www.bgchrysler.com/Service/High_Performance_B_G_Flash/high_performance_b_g_flash.html
torque management, as I understand it, it the PCM limiting the amount of initial power by adjusting the timing and fuel curve to a more conservative setting until the vehicle gets moving. It make the power come on more smoothly rather than all at once.
Someone else can better explain it than I, but that is how it was explained to me.
I looked at the site you got there... thats all for 3rd gen trucks, last time i checked this is 2nd gens.....
You are correct, this is the 2nd gen forum.
I don't know where you saw any information to lead you to that conclusion, but just to clarify for anyone else, here is a screenshot of the link above:
:crazy:
02 R/T & 05 Ram
Ditch the Jet & TB spacer, they're basically junk. Add a an M-1, a bigger TB and a BG flash. That'll wake it up real nice.
If i could go back, my first mods would be an e-fan and Fastman TB, followed by the M-1 and B&G flash from Fastman. Then all the exhaust stuff.
Ram Racer
Concerning the B&G flash. While it can give better performance I would not let them flash the stock pcm.
If you get a check engine light you will not be able to find out whats wrong by the 3x key on or with a scan tool. B&G wipes the pcm clean and doesnt put self diagnostics back in.
When I first started my 408 with a B&G I had to put in my stock computer to set the cam sync signal.
I have never modified a MPI vehicle, so my question is: when I install the stroker rotating assembly and cam, will I need to reset my cam sync signal with a stock PCM?
I though if everything is assembled according to spec (cranks pos sensor, dist postion, timing degree), the sync signal would stay the same.
If the B&G doesn't have any diagnostics does that mean that the CEL will stay on?
02 R/T & 05 Ram
yes, you still need to get the sync checked. They can vary wildly and you's never know it.
for future reference how would I go about checking and setting it?
I am compiling a hard copy of all relevant posting regarding stroker applications so when I get around to purchasing the parts and pulling the motor out I'll have them for reference, so if you go into a bit of detail that would be great.
Thanks
1 - 20 of 21 Posts
