1 - 19 of 19 Posts
I'm trying to find a stock y-pipe for my 2006 Ram 1500 5.7L to go back to stock and so far have only had a reply from a guy with one from a 2005. Are the 2005/2006 y-pipes the same?
MADBRAD
They are different. The 06 drivers side pipe runs under trans pan and connects to passenger side and 04-05 run the drivers side back closer to drive shaft to connect to passenger side.
Ahh, I was afraid of that. Thanks for the reply, hopefully someone will see this who has an 06-08 stock y-pipe sitting around!
ricer
I will have one after Monday. I am having my OEM y pipe cut off and having a Magnaflow y pipe welded on.
Discussion Starter #6
Still looking, I need the entire assembly from behind the manifolds back to the single outlet.
MADBRAD
Manifolds back cats and all. Could be tough to find. Salvage yards cant legally sell used cats.
Valdez Racing Team
do you still have your cats? might be easier to go to a muffler shop and have one made..
Discussion Starter #9
I know it will be tough, I sold mine on CL when I needed some cash. Now I need one and can't find one. I should have been more clear, I'm looking for this piece (guess I should be asking guys who switched to long tube headers).
"I'll go all in."
Does the magnaflow Y replace that piece or do you have to run LTs to use a magnaflow Y? I'd like to get rid of mine cats...
"I'll go all in."
Does it have sensor bungs in it already?
ricer
The Magnaflow y doesn't have any bungs in it. It is just a short piece of pipe replacing the OEM y, thats all, no pipe on the Magnaflow y at all.
Admin - David Mack
Here you go ...
"I'll go all in."
I thought it was an entire Y, like from the headers back... So is it really worth the money, time, and effort to get it installed?
Admin - David Mack
A number of DT members have had the y-pipe done and they said they could feel a difference in the truck. They also said they liked the new sound from the pipes. It wasn't a big change in the sound but it was very noticeable. I haven't done the change out yet but it's on the short list with a set of headers and new muffler. I'm sick of the Blowmaster noise!
New to the Hemi World
I have the factory 2007 Y-Pipe sitting in the garage.
At least the last time I checked it was in there.
What exactly do you need? The Y pipe after the cats or the cats and the Y pipe complete like in the picture you posted?
It seems that several different things are being talked about.
If you need the cats then the Magnaflow Y pipe does no good until after you have the complete factory pipe.
"I'll go all in."
I'm not the OP. ;)
I was mistaken and thought it was a Y-pipe like what comes in a LT set sorta.
1 - 19 of 19 Posts
