1 - 16 of 16 Posts
Well guys im thinkin about having my y-pipe changed out for somthing a lil better than stock and this is where the questions start. I have a borla muffler that is si 3in and dual 2 1/4 out and was curious if there would be any beniffit to having the the stock y-pipe cut off; then dual 2 1/4's ran back to the muffler and then a single 3 dump. The muffler is a straight through design so I didnt think there would be any problems if I just turned it around. Would there be any gains from this vs just replacing the stock y-pipe with a better flowing y-pipe??
That sure sounds like a waste of time and energy. Even if it was a performance increase it would be extremly small to be not worth.
Change out the Y pipe and go from there. Long tube headers would be a better bet.
from my personal experience, anything you do behind the cats yields very little gains including running true duals with no y-pipe. Swap in a set of headers, and you will feel a major difference in performance, and sound.
any input on what headers would be good for a STOCK 4.7 ????? all i have as far as performance is a homemade CAI and a Borla muffler. i dont plan on sinking a ton of money into a truck that will never see a track. i was just curious if 2......... 2 1/4 pipes into a single muffler would show any beniffits over just a y-pipe replacement with 3in back to the muffler.
I would wonder if you changed out the stock y pipe and muffler,if 2.5 inch out would be enuff for you.
I think 3 inch with a highflow muffler,new y pipe would be to much velocity being lost,and you would notice a bit of low end lost.
I know for a Hemi 3 inch single is lots,even with lots of mods.
Im sure if they used 3 inch for the 4.7 it was only to try and keep some air flowing through a restrictive stock exhaust setup.
A free flowing 2.5 inch would have a much faster flowing exhaust,than a restictive 3inch.
Which would mean a much broader tq curve.
Thats my quess.
the only reason i thought about 3in is because the muffler already has a small section of 3in on it; it starts about halfway under the cab (quad) where there is a factory clamping point at. so the exhaust is factory size till this point, i was just curious about replacing what was left of the factory pipe with somthing larger. anyone else have any inpuut on this idea of mine or should i just do the y-pipe and leave the rest alone.
72 rs, you have any sound clips of your muffler?
COUNTRYBOY1
i have a true dule exhaust with 2 2 1/4 running into two flow masters and i lost a load of TQ im about to put my stock exhaust back on.
Discussion Starter · #10 ·
not right now i dont..............i can try ang get somthing in a few days; im at work right now and im wont go home till sunday........( i work on a oil drilling rig). how do you go about posting vids anyways???
As long as your muffler is not directional, you should be ok. All you are doing is using the muffler as a y pipe, sounds like a good idea to me. If you do this let us know how it works for you, this might be somthing to think about when its time to change my y and muffler.
That would be great if you can..To post videos I use photobucket.com
If you remove the 3 inch piece and run the rest the same as stock,you should get a bit of bottom end back.
So just change out your y pipe,keep it single 2.5 or whatever stock is,and get an adapter for your 3 inch borla.
That will be the easiest,and also the best performance for your truck.
And if you do headers,youll still be setup nice.
Thats what i think.
But im just a rig pig,so what do i know.LOL.
subscribed
What headers would be a good match for a 4.7qc?
All we have available JBA's and Gibson shorties for motor. I have the jba's and there is a little gain with them, but not much.
Hemi2nV
take off those flow crappers!
1 - 16 of 16 Posts
