If you want the Skyfi to come on and go off automatically....what you will need to do is tap the power wire from your XM into your 12v Acc. wire at your radio instead of your 12v constant. the 12v Acc wire only has power when the radio is on, therefore your SkyFi will only power up when your radio is turned off
Hope that all made sense to you and helps out!
