I have a 2004 dodge ram 1500
I just received a pair of xenon hid lights. They went in real easily but aren't working. One of them flashes but I don't even see the other one flashing. I was reading other forums where people have had this problem and they removed the daytime running light fuse to fix it but I couldn't find a fuse labeled that in the fuse panel. Any help would be appreciated.
Hi and welcome to the forum but I would start on making sure that everything is grounded good, don't leave no paint or find a good place. Next check the ballasts if one is working change the one on the other side and see if it work right and if it does you might have a bad ballast. Check those and come back and let us know what you find.
I found it. I was looking around online some more and found a video of how to install them. Turns out I need to also install a set of relays to make the problem go away. I'll order them, put them in and see how it goes from there.
Awesome and when you get it done don't forget pics?
