WTB: Passenger side power window switch
1 reading
103 views 2 replies 2 participants last post by  nasty04hemi
#1 ·
Like the title says I need a passenger side window switch for my 2004 5.7 HEMI Dodge Ram 1500. Mine has stopped working and I know the window motor still works because the driver side switch still rolls down the passenger side window.
Any help is greatly appreciated. Paypal transactions only though please.
Save
#2 ·
The same thing happened to my truck. I thought i needed a new switch over there also. I took a multimeter an ran it front the master switch(aka driver door). From the relay to the passenger door. the relay wasnt closing. So i wasnt getting power to the passenger door. So I ended up needing a new master switch. I found one on dodgeparts.com for 83 dollars. I hope this might help you out. So if you have a multimeter, ill print you a copy of the switch off of alldatapro.com an email it to you if you need. Happy hunting!
Save
#3 ·
Yeah that helps a lot. I will check the relays on the driver side and see what I find. Thanks for the help bttfman1and3
Save
