Or just get the Viper Version... look at the 0-60 speed!!!!!!!!!!
http://www.hennesseyperformance.com...ekpa&DoThis=Dodge+Viper+SRT10&ActionReq=Where
2003 & Up - Viper SRT10 Venom 1000 Twin Turbo Upgrade
Power Output:
# 800 - 900+ Rear Wheel HP (900 - 1,100+ Flywheel HP)
# 900 - 1,000+ Rear Wheel Torque (1,000 - 1,200+ Flywheel Torque)
Acceleration (Stock 6-Speed Transmission):
# 0-60: 2.25 sec. *
# 1/4 mile: 9.75 sec. @ 148+ mph *
Note: * Denotes Viper World Record. Times were obtained with MT "ET Street" tires.
Click here to see the 9.75 @ 148 mph video.
Click here to see the 9.75 @ 148 mph time slip.
Includes:
# 522 CID Stroker Motor
# JE Forged Aluminum Pistons (9.0:1 compression ratio)
# JE Pro Forged Steel Wrist Pins
# Manley Pro Forged Steel Rods
# ARP 2000 Rod Bolts
# Custom Machined Factory Crankshaft (exchange)
# Polydyn Coated Rod Bearings
# Computer Balanced Rotating Assembly
# Twin Garrett Ball Bearing Turbos
# Front Mounted Intercooler
# Polished Stainless Steel Inlet Tubes
# Custom Intercooler Hoses with T-Clamps
# Stainless Steel Turbo Headers
# Stainless Steel Turbo Down Pipes
# External Wastegates
# 3 in. Stainless Steel Side Exhaust System
# Ported/Polished Cylinder Heads with Stainless Steel Valves, Upgraded Valve Springs, Titanium Retainers, 3-Angle Valve Job
# Hardened Pushrods
# Upgraded Hydraulic Lifters
# Upgraded Fuel Injectors
# Upgraded Fuel Rails
# Upgraded Fuel Pump & Fuel Lines
# Upgraded Fuel Pressure Regulator
# Centerforce Clutch Upgrade
# VDO Boost Meter
# Mobil One 15/50 Synthetic Oil & Mobile One Filter
# All Necessary Gaskets & Fluids
# Air/Fuel Calibration
# Exclusive Venom 1000 Twin Turbo Exterior Emblems
# Exclusive Hennessey Emblem on Rear Bumper
# Serial Numbered, Limited Edition Dash Plaque
# Professional Installation
# Road Testing & Chassis Dyno Testing
# Allow 16 weeks for installation with prior appointment
