1) IS there another good way to run the power wire besides in the truck? i have 1/0 gauge and its kinda large to run under the carpet and since the carpets pretty tight in these im sure you would see the wiring! I was thinking under the truck in some PVC or garden house with brackets mounted to the frame rail or something then up into the rear seat cubbys since there are a few holes under there? Just a thought....
2) I am running the new Boston Acoustics SL60 components and dont really like the idea of having to run the new wires though the plastic plugs in the doors? anyone have a good suggestion how to do that OR can I use the stock wiring up at the radio to run those off my amp? its only a Boston GT20 amp which is 45x2 rms but i wasnt sure if that amount of power was safe to run through the stock wiring? I was gonna run the wires from the amp to those wires behind the radio and be set, just want to see if it'll work(be safe) on the stock wiring?
