Thanks for the advice guy's. I had seen Waytek on another post for someone looking to upgrade some audio equipment and they have a terrific selection and at what I think are pretty reasonable prices for the quality. I had planned on building my own harness for under the hood and all the lighting since the precvious owner completed an engine swap using a sledge hammer and chainsaw, nothing is as it should be. Someone had performed some surgery on the stereo and a lot of butt connectors on the steering column. After reading thru these comments I will probably do as suggected and treat the old harnes as a road map and build my own. I'm odd, I actually enjoy wiring and body work too, although this rig will not ever see new paint. AS to wire size, I DEFINETLY agree, I couldn't believe home much 18ga is used, scarey. I will probably eliminate all of the fusable links, I was thinking 50a maxi-fuses instead of circuit breakers (share any thoughts). Also, I haven't had any problems with mine, but I 've read enough that the ammeter is bad news, I believe I actually have a volt meter in my dash (trucks inTN, I'm in FLA) Whenever this project gets off the ground, and more importantly when it gets completed I'll throw some pics up too if anyone is interested. Thanks to everyone again, and please let me know if anyone has tried anything simple under the hood on their own...Brian
