1 - 2 of 2 Posts
92 Dodge grand caravan 3.3 L
The windshield washer hose to the passenger side wiper needed replacement. It was a black rubber hose. To get it off of the fitting i had to use a screwdriver to push it off. I am not sure if it was calcium that held it on or if it was glued.
I had a clear vinel tube of the same diameter 1/8" and it went on the fittings hard. The fittings are completely smooth with no barbs.
I gave it a try and the vinel tube leaks badly on both ends, for some reason not sealing on the fitting. I tried polishing the fitting as it is a copper tube about 1/2 inch long, but it did not help.
Does anyone know if the factory glues the ends of the hose on the fittings or do i just need special washer hose.
Thank you
Wally
1 - 2 of 2 Posts
