My front driver's window stopped working on my 2001 D and I removed the door panel and waterdam and after trying to get my window up manually, I pulled the glass itself out of the regulator window channel. This is the piece that is held in by the two bolts that you have to lower the window to access. Is there any special way the glass gets placed back into the channel when I replace the regulator? Also, are there pictures on this forum that shows what I need to do to replace the regulator assembly. Where should I buy a new one? Any ideas are greatly appreciated.
