1 - 3 of 3 Posts
Recently bought 92 Dodge D150 two wheel drive with a 318. When I bought the truck it had be parked since 03 and was missing the ecm. So I ordered everything for the firing system. Ecm, plugs, wires, coil, the whole distributor. Replaced that then found out that the entire fuel system was compromise so I cleaned the fuel tank replaced pump, filter, injectors. I didn't replace the pressure regulator bc not its getting plenty of fuel now. And still it sound like its got a mild cam. Hard starts and if I touch the throttle it wants to die. If I let it idle the rpms ramp up and down. I have removed the catalytic converter replaced the 02 sensor. I plan on changing the crank sensor tomorrow. If that doesnt help I'm going to have to move to iac and map sensors any help would be great thank you
1 - 3 of 3 Posts
