1 - 6 of 6 Posts
Mmmmmmmmm, beer.
As some of you might recall, I am in the process of lifting my truck mildly. First step was the gears (done now). Next step is a Skyjacker 2" lift. Last step is larger tires to go on a set of 2001 17" Off-Road rims. I was planning to run a 285/70/17. Now that I have the 4.11's, i'm pretty sure I could easily run a 305/70/17. Problem is, not sure if 2" lift is enough to run a 305/70/17 without rubbing.
Anyone tried running a 305/70/17 with only 2" of lift? Did it rub?
I think the Off-Road editions are lifted 2" Anyone run a 305/70/17 on an Off-Road edition? Did it rub?
Please, pics if you got 'em.
I disgaree...:)
305's rubbed on my 2000 Off Road. Just slightly on the plastic inner fender at full lock, but they do rub and it would be much worse if you hit a bump.
Here is mine with stock 2".
Here is mine with a 2" coil spacer added. Plenty of room now, and no rubbing even while wheeling.
How`s the front sitting with the spacers? I have Daystars, and it`s about 1/2 - 3/4 inch higher in the front.
I disgaree...:)
It is sitting level now, but with a small load of 300-400 lbs it is lower in the rear. I am going to put a 1" block in the rear or maybe a 1.5" AAL.
i have 305/70R16 but they are little shorter than on 17" wheels, i have the 2" daystars and no rub with alot of b.s.
1 - 6 of 6 Posts
