Need to replace my ball joints, and trying to figure out which ones are the best.
Thanks - Ryan
i can only think of Carli suspension ones being greasable, but there are $$$ and only make the uppers...
Check out Moog.
Well... I broke down and bought some greasable Precision ball joints from Napa. They were pretty salty at approximately $95 per joint, so I hope these last longer than the orginals.
Took my truck into the dealer today to have the engine reflashed under recall, and I was giving them some grief about all the parts worn out on my truck at 53k miles. Upper ball joints, front axle u-joints, unit hub bearings, etc. They claim that its uncommon to wear out this early.
Weenie Wagon Man
Well with only 50,000 mile on my 2003 Dodge 2500, SLT, with Hemi 5.7L, I found through inspection that I once again have to replace the lower ball joints for a second time and now also the uppers as well. NOT common???? Looks like Moog is the way to go.
well... I hope the napa brand will hold up... I will grease them every 5k miles.
I also complained to the dealer about the reports I've heard about the rear shaft u-joints seizing, which is common on non-greasable joints. The mechanic actually tried to tell me that greasable jionts can cause a worse vibration than factory jionts. I've never heard anything like that before.
hopefully the front end work will fix my vibe issue.
