I am installing driving lights. Need to know which wire is for high beam. The "tap" wire for the driving light relay is between the battery and radiator right now where most harnesses are. Also: is the factory wire negative at that point or positive. I don't want to probe the wrong wire and hurt something / set off the air bags etc. And I don't want to disassemble the darn truck to get to the back of the headlight assembly to look at the wires..... if it is a negative switch, I know I have to use a relay with the coil ground to the negative HL switched wire. There are a LOT of wires in that area and all difficult to get at. Also: I could tap the high-beam wire at the switch if I knew which one. So either location......
Thanks
Thanks
