1 - 20 of 26 Posts
they are for the heater and ac controls.
thanks
If you want to go with LED, there was a big thread about this with part numbers, and a how to. If you want stock, then those are dealer item bulbs. Its the only place I have found them
thanks.
how much did they cost if you can remember?
are they supposed to look all burnt up like that?
Discussion Starter #5
thanks.
i just want my stock ones.
Those OEM bulbs are available through dealer, about $8 each. Mines look just like yours, burned look.
I think the following side has LED bulb for it without any modification.
http://superbrightleds.com/instrument.html
Discussion Starter #7
8 BUCKS! i wasnt thinking this would cost 24 bucks. thanks for the link. i hope the led are cheaper.
Discussion Starter #8 (Edited)
are the stock ones clear or green?
will i have any problems with them matching the color of the stock ones?
I did bring the bulb to show at the dealer parts counter. At first, they didn't know what it was, so i had to explain where it was from. After I heard it was $8 each, I ordered just one even I wanted to have a few. Oh yeah, I had to pay in advance..... Sure felt like got ripped off.
The aftermarket LED is listed as $1.29 each. But i don't know which one fits.
Let us know how they work if you got the aftermarket LED.
There clear, but I think its the HVAC control background that makes them have color
Discussion Starter #11
are the stock ones 5mm?
Discussion Starter #12
yes your right. i just held a light behind the control background and the colors cam out.
I think the original is clear but the replacement from the dealer was covered with blue vinyl.
As far as size goes, I'm not sure if they go by the hight or base circle diameter.
Are you guys sure about that price? I just looked up the part number, and if I'm correct (part #5013815AA) the MSRP was $2.00 and the online price was $1.54.
Well, I guess I got ripped off by the dealer really bad.........
I will take a look at the receipt.....not that I can do anything about it now though.
Those OEM bulbs are quite expensive. Not 8 per bulb, but I paid 1.90 per bulb.
The LED's from superbrightled's are great. I have done the complete LED conversion.
Thats bright :tup:
Discussion Starter #19
ill be making a trip down to the my local dealer tomorrow and see what their asking for. id rather have stock. but im not paying 8 dollars a bulb. thanks for the part number. i found them on dodgeparts.com. i will be buying them from there with a powersteering pump that i need.
i just payed 7 bucks a peice for them at the dealer. :mad:
1 - 20 of 26 Posts
