HI
I have recently installed a 6 inch RCX lift in my 09 ram 1500, I need some after market wheels, what is the new back spacing I will need to clear my new knuckles?
Depending on the width of your tires, 5" backspace will give you clearance from your knuckles but keep your tires tucked slightly inward toward the truck. 4.5" backspace will give you the most clearance and stick out away from the truck a little more
Thanks for info, I am currenetly running stock wheels with half inch spacer up front, and one and one half spacer on the rear to get the correct track width, any adivice on that set up.
my sig has what i use
