how can i stop the annoying wheel hop i get when the tires spin in 1st? when i spin em in 2nd its fine. will new springs help? bushings?im on the stock 15" rims & tires
this is normally said by most mopar intusiasts... but im here to say its a bunch of bs... i just got urathane motor mount inserts and in fact my wheel hop seems like 5 times worse ... off the line its freaking horrible now ... but atleast when im just taking off in first and hammer on it , it just spins in first n 2nd instead of jumping off the road... but for dead stop launching made my wheel hope way worse... so now im dumping money into my suspension... no use having more HP if i cant get it to the ground... figured id get mopar stage 3 struts, strut tower bars, after market sway bars, suspension bushings... and if that dont work ima be pist lol! also for tires the better tire u get the more wheel hop in my opionon since there trying to grab harder and cant... atleast in my case... cause before inserts if i took off normal and floored it when i hit full spool there was mass wheel hop not its just a spin! but yea off the line they didnt help me at all!dodgeneonACR98 said:Motor mount inserts will stop alot of the wheel hop. Infact, 99% of the wheel hop in these Neons is from the motor mounts. The prothane inserts from Howell automotive are cheap and effective for this. Good luck!
No offense, I'm trying to help you, but I think you nailed it right on the head. Its your technique thats causing massive wheelhop, the stock mounts are just amplifying it.rymeswithorange said:i drop the clutch hard,,start the wheels spinning,,then as im feathering the throttle back to get the tires to hook is when the hop starts,,right at the point of traction,,erch erch erch,,then i hammer it again and go...i dunno,,maybe it is my technique
:thatfunny :thatfunny :thatfunny :thatfunny :thatfunny :thatfunny :thatfunnyRice_Eater said:Yeah, not all of us are blessed with adjustable suspensions....
And if it cant spin, you dont have enough power. __________________
95moparracer said:well srt-4's dont even have a front motor mount and not sure on the rear bobble set up cause well face it u cant see shit the turbo on top and alotta plastic junk and then the ic lines block the [email protected]! i'll have to un hook my ic line and check it out! and yes im using the same tires and same road lol! idk somedays its prolly my driving.... i know how to launch thoughjust its a lil diff in my srt-4 then my 1st gen!
Isnt that exactly what I said before? :huh:05hemiregcab said:And you wont get wheel hop if all you do is spin!! Wheel hop is caused from the car catchin a little traction then spinnin, then catchin a little more traction, then spining again.. that repeats itselt which in turn causes wheel hop!
u can hook 1000 hp ! ever see a S/S hemi-dart stand straight in the air off the line? u dont lift the wheels spinning. not enough power my ass! LOLrice_eater said:Yeah, not all of us are blessed with adjustable suspensions....
And if it cant spin, you dont have enough power.![]()
WHAT!!! You cant lift the front end up and send the tires up in smoke at the same time!!! THEY DID IT ON F&F, IT MUST BE TRUE!!!!! :WHT:underdodge said:u can hook 1000 hp ! ever see a S/S hemi-dart stand straight in the air off the line? u dont lift the wheels spinning. not enough power my ass! LOL
