1 - 20 of 90 Posts
Creature Of The Wheel
lets list all our problems. don't be shy..lol i'll go first.
cracked dash (like an inch or 2 long)
driver's side door panel is very loose (sev clips must be broke)
front bumper pad is loose(even with a new bumper, pad & all...lol)
one cargo light is broke (did this yesturday trying to change the bulb)
crappy tires (curb rash & very uneven wear)
scratches & dings everywhere..i think i get a new one everyday
hella lights aren't hooked up (too lazy)
broke cupholder (one of the tabs broke & its barely hanging on)
vent broke...the adjustment knob broke.
its a sluggish hesitating pig...it'll be fine for a few days then its back to being a slug
ride is hell...due to crappy tires...too crap to rotate & balance & i don't feel like getting a new set of $600 plus tires for a worn out beaten up truck
just a couple things.
I WISH I WAS GREEN
Fog light switch is pushed in with the clip broken
Driver side power window/locks switch is also pushed in with the clip broken
Duel steering stabilizer bracket is bent
power steering leak somewhere
small oil leak somewhere on the back side of the engine
paint is peeling down to primer
hood fitment sucks the big one
but I still love her
i forgot something...my power windows roll down/up really slow. my new black grille don't fit perfectly. my headlights are kinda yellow & hazy.
1. no front bumper
2. cracked grill
3. rear bumper dents
4. left front turn lens cracked
5. cracked dash
6. TRE'S need replacing
7. need back brakes...
8. dent lower bedside near cab
9. tranny pan leaking slightly(reused oem gasket like 5x's lol)
10. trac lok needs rebuilding
11. trac bar
iam sure theres more....to late to think
Cracked dash (fixed it with a overlay)
passenger and drivers door panels are loose (need to replace clips but where do i get them?)
Rear suicide doors dont open (the wire on the latch broke)
Squeeeky cab when i hit bumps? (cant find source)
Burnt headlight bulbs
Leaky rear main seal ( looses about a quart every 2 months)
too much bed flex
Dents on doors
Tires rub
Ive replaced all the lights on the outside/inside
NO engine work! The truck runs GREAT
interior is in great shape
paint is in ok shape (its getting beat up on the doors by the roof)
i wont sell her
Bridal Veil Falls
Plenum Leak.....
Cracked Dash....
Scratches, some from letting my son drive it in the back yard and running over my turkey frier......
I need to put the 14x3 hat on and install my Efans to get the power out of her....
Fixed the brakes finally....
Paint peeling badly on the hood.
Painted over paint peeling badly on the roof.
Rust on botom of driver's door
Feels like a slug about 70% of the time.
Crappy unevenly worn tires
I seem to replace a couple ball joints and or tie-rod ends yearly
Makes a weird air leak noise when I first start it up from cold.
Fogged up headlights that get condensation in them CONSTANTLY because last owner drilled "drain holes"
Scrathes and chips in the paint everywhere.
Motor is very dirty
headliner is deteriorating
latch on rear sliding window is gone
one hinge on the glove box is broken
Chrome rear bumper has lost the battle with rust
Chrome grill has a few "bubbles"
driver's door switch was glued shut by previous owner.
visor over Driver's window has a crack.
spare tire cable broke
That's all I can think of right now.
1. Suspension squeak due to hitting a puddle doing 40
2. door dings due to idiots in parking lots
3. peeling paint due to bad primer
4. dash bezzle starting to come apart from the dash
5. cracked dash piece under steering wheel
6. broke fuse door
7. duct taped license plate lights
8. ziptied on grill
Thats all I can think of now
Mopar owner since 1977
All the "problems" that my ram has...
can fixed by a simply application of
CASH!
So the problem(s) is/are not the truck,
but lack of funding.
Lack of funding=disrepair
and/ or compromising by purchasing poorly
fitting parts from non factory suppliers.
99 2500 Laramie SLT
-Doesn't run (bad coil)
-cracked dash
-crack in trim in front of gauges
-trac bar
-tie rod ends
-ball joints (7k miles on replacements of replacements)
-oil pan rotted out (literally chunks falling off)
-trans pan (same as above)
-muffler
-steering kncok and rattle
-tailgate cable snapped
-driver's window sometimes doesn't go up in wet, snowy weather (power)
-spring in latch of rear door bottom missing and rattles
-brake lines and cooling lines rusting out
-A/C compressor was just replaced due to bad bearings
This truck only has 82k miles....
-cracked dash
-bad steering
-scratches on hood from wind storm
-vinyl floor bubbling
That's it:)
It's a constant project, as we all know. But I love her.
Senór Member
dash crack(it's in [email protected]#king PIECES now almost....:VHOT:
suspension sucks donkey balls
squeaks a lot
seat tear
some various seepages
interior looks like shit
paint sucks
roof looks weird from corrosion
and some more schtuff...:SPIN:
Hood and roof paint is looking very faded.
Dash is cracked (really want to get it fixed)
Bezel is cracked (ordered a "new" one already)
Head light/fog light yellow (only one side :huh:)
A few dings/scuffs here and there
Green Giant
Power windows are deathily slow to go up
California Pinstripes on 90% of body (result of jeep trails)
cracked grill (rocks)
bent bumpers front and back (rocks)
exhaust leak (rust and rocks combined)
one front control arm has a large dent (rocks)
driver seat starting to separate where I slide out
But none of these issues bother me that much cause theyre like battle scars. (except the windows..)
And now, steering box is leaking like a sieve at both shaft seals. I put steering fluid made by Prestone that specifically says it is for Dodge and I think it ate the seals.:mad:
I have freakin play in the steering I can't seem to get rid of!! Argggghhh!!
I watch my plenum like a hawk, it's still original
Possible fuel pressure reg/filter or injector issue beginning, cranks a bit longer then starts when she sits for over an hour or longer
9 years,72K miles, second trans, second front end, third set of tires, second set of brake rotors second sound system.
Why do I keep it? Hell it's paid for!!!:) 170bcuda
Bridal Veil Falls
There is an article in one of the threads about how to fix that stearing slop....
I saw the post but can't access pics for some reason. I can't tell you how aggravating this is. I was always a Ford guy but got tired of fixing those trucks. My Dad had a 99 Ram with a Cummins and never had any problems with it so I bought this one kind of by his gushing over how great the trucks are.
Black Sunshine!
:silent:
1. Rust haha
2. cracked dash
3. driver's side door panel is loose
4. bondo
5. dents and scratches in body :mad:
6. plenum is bad
7. 4 low is shot
8. bad bushing on sway bar I think - balding pass. tire
9. heater core is going bad
10. clutch is shot
11. CAD is pretty banged up but works haha
12. Parking brake is lose to point it wont work :rolleyes:
13. Drips oil from here and there
:bawl::bawl::bawl:
but but but its still my baby and I'm going to fix everything and more :D
'speck my authoritai!
Good thread idea!!!
Plenum Gasket blown
Leaking steering box
Oil needs changing
Front Suspension worn out
2 Holes in drivers seat
Broken grille
Goodyear TD tires suck
A/C doesnt work
Thats about it I think. But at 175,000 miles it runs and looks great!!!
1 - 20 of 90 Posts
