1 - 2 of 2 Posts
I just installed the BullyDog Outlook Monitor. It get's the Trans Temp from the transmission sump temperature probe that is connected to the TCM.
I am curious of what the normal temps are for a few scenarios. Please indicate whether you are using the same probe as me for your readings or a mechanical aftermarket probe as I suspect this will be slightly different. Also, how long does it take to get up to a steady temp?
Weather, cloudy and 45 degrees.
1. 30 mph through neighborhood type back roads, light throttle.
2. Freeway, no hills, about 65 MPH unloaded
3. Towing 6K same conditions as #2
Thanks for the help.
#2 is like 150 to 165 and #3 is like 165 to 180 for me ( hills it does up up a little) i have autometer trans temp... i think at is about normal.. i do have a shift kit and big pan... also hope that helped
1 - 2 of 2 Posts
