1 - 12 of 12 Posts
My brothers truck (05 1500 4x4) has almost 80,000 miles on it and lately it has some grinding coming from the front end. It only does it when you turn it the extreme left and some times to the extreme right, but not always. I told him that its probably the cv joints but i wasn't sure. Im new to the independent front suspension and am not familiar how the whole thing works. Some advice or links would be great. What I really want to know is how the cv joints work and how easy is it to replace. Thanks
I also had a grinding noise from the front end. I was expecting the worse. Turned out it was low on power steering fluid and made the noise when I took my foot off the brake and hit the gas peddle to accelarate. Guess the pump speeded up with the engine and was starved for fluid. You might also be starving the pump for fluid when you turn the wheel all the way to one side??
:D Hello!!!
80000 on an '05? geese I thought my 27k was high..... What motor?
:huh: :help: i hear the same thing on my 02 with 85000...i can hear a type low whoosh whoosh occassionally. The guy i know at the shop said it might be a bearing. its expensive to replace and its hit or miss with em...????doesnt effect how it drives whatsoever :huh: :help:
From your description, it does sound like it could be your bearing on the right side. When you turn extreme left, it's putting pressure on the right side wheel.
Its got a hemi.
The reason it has so many miles is that we put around 1000 miles a week on it driving to and from work. Believe me its not exactly the best truck to drive that far every day with. But plenty of power to haul tools and stuff(mainly a$$)
Hmmm...I have the same noise. I guess I can try the power steering fluid.
Any special kind or just basic?
:D Hello!!!
hemiram_05 said:
Its got a hemi.
Wow! I put 15k on mine in the first 6 months. Have you had anything give you problems other than in this thread?
I just noticed your screen name....Man it pays to read those. Lol
Discussion Starter · #10 ·
Actually the truck im talking about is my brothers so you had good reason to ask. This is the first trouble he's had out of it. Other than turning in parking lots(sharp turns). Its still doing great. He has had 3 2nd gen rams in the past and he says that this is by far the best one yet. On the 2nd gen he allways had u-joints and wheel bearings going out.
You need to get the stuff Dodge recommends - it isn't the basic stuff. I don't have access to my owners manual right now. Sorry.
All Around Great Guy
ATF+4 IS WHAT YOU NEED. Many 3 gen rams have leaky return lines.
1 - 12 of 12 Posts
