1 - 6 of 6 Posts
I got an enging light the other day, I did the IGN trick and the only code that came up was the following...
U1120
I am aware most codes are P codes to I'm kinda baffeled here, so i went to this site and found the following info, I don't know if I decipfered it correctly.
http://www.***************/m_555666/mpage_1/key_/tm.htm
U = Network
1 = Manufacture Specific
1 = Fuel & Air Metering
2 = Fuel & Air Metering
0 = Total System
Anybody have a clue what the world is going on??? what I should look for?
Thanks in advance! Glider
cuban11182 said:
What is the IGN trick?
Start with the key off, turn it to on and back to off 3 times, leaving it in the on position. It all has to happen within 4 seconds or so.
Your codes appear on the odometer.
cuban11182 said:
Ahh sweet thanks...no need to purchase an obd 2 then huh
Its much easier to look it up with a code scanner...the key thing works about 1 out of every 8 times you try it, then you have to write the codes down and look them up.
Could you recomend a couple brands of scanners for the garage enthusist? I don't know one from the other and don't know if the ones at my local Shucks autoparts are worh a crap.. Thanks!
1 - 6 of 6 Posts
