I know this subject gets beat to death but I just bought a set of wheels and am looking to see what tire size I should be looking at.
Wheels are 20x10 Ultra Baja Champs, -25mm offset (not sure of back spacing)...my truck (08 1500 Reg Cab) is stock ride height currently.
Thanks,
Jeff
Discussion Starter · #2 ·
Found out the back spacing is 4.5", I know the tires will stick out quite a bit from the fender but if anyone has pics of a similar setup please post pics so I can decide on what tire size to get.
I have a feeling that a 305 will be a tad too wide, and was told a 275 won't fit.
alright, well...45 views and not a single post? I guess I'll just take a chance...I searched and it seems as though 305/55 or 305/50 will be fine, but with a wheel this style, I can't justify getting a street tire in the 50 series, may find out of the Cooper Zeon LTZ is available in this size.
Go to your local tire shop and have them test fit the tires you want until you get your desired look.
I'm more worried about rubbing honestly, being at stock ride height I just want to be sure with the specs on the wheel, that a 305/55 won't be too big and cause issues. I know with 4.5" of backspacing they will stick out pretty far, which is ok.
That's why I am suggesting that the tire shop do a test for yah. If you don't like the look with the first tire then have them suggest another size until you are happy.
Cool, thanks. Never knew a tire shop would do that, maybe it's just this area but dudes at these tires shops are DICKS lol.
If they don't want to help then take your money elsewhere.
