1 - 10 of 10 Posts
2002 Ram 1500 4x4..
I want to level the front end a bit, and I understand that I can just tighten the torsion bars by about 4-5 complete turns to do so?
What size socket do I need to do this?
Any 'side effects' of doing this? Do I need to get it re-aligned?
Up The Irons!
18mm. I did mine 3.5 turns and it rides/stops/handles fine. Only thing I noticed is that the pull it used to have to the left at highway speeds got a little stronger....still barely noticeable though. The new position of the wheels my increase the "off-ness" of whatever is slightly out of alignment. I'm getting it aligned in the next month or so anyways.
Dang.. I went out to go 'crank em' .. but the drivers side is inaccessible without removing some 'stuff'.. the passenger side, I tried but couldn't get it to move.. I may have to get a 'breaker bar' to get that sucker to turn..
Should I lift the front of the truck off the ground with a jack to do this??
Up The Irons!
Mine was on the ground, and actually facing downhill so there was more weight shifted to the front suspension. I used just a regular Craftsman 1/2 inch drive ratchet and shallow 18mm socket. It was in fact rather hard to turn, but I just went 1/4-turn at a time.
What is in the way....skid plate of some sort? They should be pretty much out in the open.
Yeah, getting the front up will make it much easier to turn them.
Hmm.. turns out I was trying to crank the wrong thing (d'oh!)... I was trying to tighten the crossmember bolt... LOL .. didn't realize the adjustment for the torsion bar was perpendicular to the actual torsion bar!!! LOL... I went out and adjusted them a few minutes ago.. when you're trying to turn the correct bolt, it's a lot easier :)
fyi - I just had my torsion bars adjusted at the dealership. The truck looks much better (40 inches from the top of the wheel well to the ground on all 4 now). Also, the dealership said this will have no impact on the warranty.
1 - 10 of 10 Posts
