I'm doing my cam and head swap and curious what these two sensors are and are they a wear part?
First is on the intake manifold towards the front and the second is kind of under it
Discussion Starter #2
I don't know how to do multiple pictures off my phone yet sorry..
First one is your MAP sensor and the second one is your coolant temp sensor. If you decide to replace them please go with OEM. Aftermarket sensors will only give you headaches.
Discussion Starter #4
Well I am getting a good coolant reading, and as far as map sensor im not throwing a code. Is it worth replacing regardless? I think it was easy enough to get to without having to remove stuff. I am just doing all the maintenance stuff I can while it's down
