1 - 6 of 6 Posts
The Malfunction Indicator Light came on in the instrument cluster yesterday so i plugged in the superchips programmer to run the DTC code reader. It said the code was P0441 which is the Evap Purge Flow Monitor. What is it, what does it do and what do i need to do to fix it? Thank you to anybody who can help!
2004 Black_Hemi_QC
Check your gas cap. Make sure it is tight.
~3 tOns oF fUn~
you can unplug the evap purge solenoid and get something like 19+ hp with no side effects...I've tried it and there's a noticeable difference in low end and mid range power, I don't know all of the details but there's a huge thread on DTW about it. I unplug mine every once in a while...
~3 tOns oF fUn~
it isn't the gas cap, I had the same code, something about the pump going bad.
1 - 6 of 6 Posts
