1 - 3 of 3 Posts
Hi all,
Just wondering: I did a DPF delete on my truck, so now its a straight Turbo-back 5" pipe. Since I dont have those filters to clog, can I burn other fuels than ULSD? Such as older Low Sulphur Diesel, or maybe a higher BioDiesel blend, B15 or B20?
hey just wondering was the installation of the 5" dpf pipe easy or was there alot of extra work that had to be done such as moving the tranny crossmember
I didnt remove the crossmember, I opted to cut the turbo downpipe in half with a sawzall. Probably not the best choice, but moving that crossmember would be a bitch. Otherwise the install was a snap, but you should definitely spot weld the joints in the pipes. I went offroading a while back with just the pipe clamps, and the exhaust fell right off the truck.
1 - 3 of 3 Posts
