41 - 52 of 52 Posts
If I used amsoil I definitly would not do 5000 mile oil changes. I'd be going to the 10000 mark. I go 4000 with dino oil. I've heard mechanics say that is conservative. More oil changes is more $$$ for the car business. I don't know. I just get more confused as I read forums.
And when you're using Amsoil, how do you change a filter at 10000 without changing the oil? You'd have to loose quite a bit when you change filters. I know all of it doesn't sit in the pan.
Using an Amsoil filter and the extended run version of their oil they say you can go 25,000miles... ehhh I dunno if I would do that.
I've never done a filter change without changing the oil.. so I can't say how much you would loose, I would guess atleast a quart, maybe 2...
Save
i use 5w20 mobil1 full synthetic "extended performance" in both my 05 hemi d (with 76k miles), and my 03 elantra (with 135k miles), and soon my 302 ranger. it claims it can go 15k miles between a change. I change the oil and mobil1 EP filter at 10k. I changed my hemi last night at 9800 and the oil looked BRAND NEW.
does anyone use this? or know anything about it?
Save
i'm using 5W-30 Mobil 1 Full syn extended performance but i change oil every 6k miles w the oem filter...i will put the EP moibl 1 filter today and i think i change it in 10K next time
Save
I've been running Mobil 10W30 (non-syn) in my 04/4.7L/74K miles for the past 20,000 miles without a problem. Since it typically stays hot day and night here in FL, I may switch to 5W30 around October see if there is any change during the winter.
Save
i just switch to Mobile1 5W30 Full Synthetic with the mobile1 filter this weekend. the d seems to run a little bit cooler with the full synthetic.... its been around 100 everyday here in texas.
Save
I used 5w 30, as i cant get 5w 20 here in England, well i can but it would cost me well over $100 for an oil change if i did
Save
How many quarts does everyone's D use? Usually it takes about 7.5 to fill mine to the mark on the dip stick. Does anyone know if the dipsticks are just too short and it's a bad design or should the D take that much oil? I'm wondering if I'm putting too much in and it's costing me some power.
http://www.amsoil.com/scripts/runisa.dll?amsoiloaf:index
CAPACITIES
Engine, with filter..........7.0 quarts[1]
Cooling System, Initial Fill..........16.0 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, 42RLE Initial Fill..........4.0 quarts[2]
Automatic Transmission, 545RFE 2WD Initial Fill..........5.5 quarts[2]
Automatic Transmission, 545RFE 4WD Initial Fill..........6.6 quarts[2]
Automatic Transmission, Total Fill
4 speed 42RLE..........8.8 quarts
5 speed 545RFE 4WD..........14.0 quarts
5 speed 545RFE 2WD..........14.0 quarts
Differential, C205F Front..........3.4 pints[3]
Differential, with 8.25 ring gear Rear..........4.2 pints[4]
Differential, with 9.25 ring gear Rear..........4.4 pints[5]
Transfer Case,NV144..........1.7 pints
Transfer Case,NV244..........3.4 pints
I use the mobile 1 clean 5000 and the mobile 1 ep filter in my durango an my 87 k5 Jimmy and it helps out great with the mileage in the Jimmy.
Save
41 - 52 of 52 Posts
