1 - 20 of 20 Posts
Just curious on your guys setup, the way you tow, tow/haul mode? manual shifting? weight of your trailer and mpg that your getting?
first time towing with my 2014 ram 1500 8 speed hemi, 3.92 gears, trailer is 26 FT and weights 5400lbs I get 11-12mpg not sure if this is accurate or am I not getting the mileage I should be? I live in alberta and yes there is quite a bit of hills here.
2004 Black_Hemi_QC
I have a 04 Dodge Ram 1500 4x4 Quad cab and I tow a a TT with a gvw of 5500 lbs....I tow it in tow haul mode and often go to campsites that involve mountains here in BC. I get about 8 mpg
So im guessing my mileage isn't all that bad then ?
What is yours in L/100km?
Mines about 23 when towing
Mmmmmmmmm, beer.
I've had two different setups with this Ram, which is an '09 1500 4x4 Crew Cab with hemi and 3:55 gears. Since I live in Colorado, everywhere I tow means I am in the mountains at some point, but we have also done some longer trips out of the state. I always tow with tow/haul on.
The first was a 24' travel trailer that weighed about 5000lbs fully loaded. Truck pulled it like it wasn't even there, but I averaged anywhere from 9mpg up to 13.5mpg depending on where I was going. Ironically, towing on the interstate and open highways or anywhere that I had speeds over 55mpg yielded the worst mpg. I saw this time and time again. For example, from Colorado to Yellowstone, I average 9-10 mpg on the interstate and across open Wyoming doing 60-65 mph. But then for the days I pulled the camper around Yellowstone, and speeds were 45-55 at the most, I was consistently between 12 and 13.5mpg.
The second setup is my new camper that I just got. It is a 30' travel trailer that weighs 6500lbs fully loaded. I have only had one trip with it so far that was to a place I have never been before (so couldn't compare to how the old camper might have done because this was a new location and route). It was mostly open highway and some mountain pass, and I averaged 10.5. I can feel this trailer there more then my old one, but the truck still handles it fine. I'm well within its tow capability. I have a trip coming up in a few weeks that is one of my regular yearly trips. I typically got 13-13.5 on that trip with the old camper because it is a lot of 45-50 mph driving through the mountains and back country roads. I will be curious to see how it goes with this new camper going on a trip like this that I have done many times and have solid numbers to compare to.
UPDATE: I averaged 10.5-11.0 mpg on the trip. So that is a loss of about 2-3 mpg compared to my older/lighter camper.
That guy
I tow about 4K or so and get around 11. I stay around 75 and 80 mph so I dont feel bad about it.
locogk
when we had our 1500 hemi 8 speed 3:92 gears 35 ft camper going from ga to ct we got about 6 to 8 mpg i have since purchased a 2500 6.7 towing first time in about 3 weeks
2014 1500 4x4 crew cab 5.7L, 6 speed, 3.55 axle. I use tow/haul when towing my 32' travel trailer which is 7600 GTW. I have been getting 8.5-10 mpg. I use the recommended 89 octane while towing.
2011 4x4 5.7 w/ 3.55s and towing roughly 6000#s and I get roughly 9-12 mpg. I run 500 miles from central PA to the mountains of the Adirondacks. My worst mileage is on the hwys at 65. On the secondary roads in tow/haul, at around 50-55 I get my best mileage. I figure the extra height of the trailer hurts more at speed. She's close to 11' high.
I'm the odd ball here and have a 4.7l. I have a 27ft 6700lbs full camper and average about 9 to 13.5 through Arizona and the mountains here. Anyone running a power programer? Which one and does it help with the tow?
locogk
thats what we started with a 4.7 pulled a couple of our campers great but they were smaller than the one we have now
2004 5,7L Hemi 3.92 ratio in both front and rear All Wheel Drive 29' Passport Ultralite total weight per CAT scale 13,600# 8.4-9.4 mpg over 8000 miles of FL-PA driving
Normally keep speed to 60 max for economy and limits of trailer tires.
I have. '12 1500 with the 4.7. Tow a TT that is about 6800lbs. Only upgrade I'm using s superchips tow tune and average about 10-11mpg. Even towing through the mountains.
I towed a 14ft cargo trailer to Maine and back, 3900 miles. I got 8 mpg coming and going. No tune, reg octane, 70 to 75 on the highways. I developed the Dodge tick on that trip. Even changed the oil in Maine. I will be going back up for 2 weeks of hunting soon, and won't be towing anything. I may bring my large ATV back if it will fit between the Ramboxes. Interested to see what the mileage is up and then back if I load it up.
Jimmy
Just finished up a 1700 mile loop from Idaho Falls down to Southern UT and back. I have a 2015 Ram 2500 6.4, 4.10 rear, pulling a 34ft fifth wheel that is about 10,800 lbs loaded and going down the road. I drove the speed limit except where it was 80 mph and then I held it down to 75 mph. A lot of hills and mountain passes. Hwy UT-20 from I-15 over to Panguitch is a pretty brutal climb. Truck did excellent tranny temps never topped 185 degrees. Averaged 7.96 miles per gallon for the trip.
32 ft Rockwood TT; 7500 lbs; 850 lbs on the ball; 25K km traveled. Typically anywhere between 21L/100 km and 28L/100 km. Seen 18L/100 km on occasion when conditions are just right.
We upsized our 7'x16' V nose to a 8.5'x20' car hauler to accomodate a sidecar addition to my 05 HD Road Glide in 2015.
Total wgt near 5,000 lbs. Mpg with mid grade fuel on the 2013 Laramie 4x4, 5.7L, 8 speed was 13mpg flat level under 64mph with cruise engaged. Hills and higher speed would drop it to 7-8 mpg and I drop gears on climbs.
Hauler is being converted to "Appalachian" sleeper with 'suicide' RV door, 3 windows, canopy, and stored bed box for Aero queen.
I have averaged around 8.5 - 10 pulling my 26' Nash. I have a '10, 1500 with the 5.7 and 3.92 gears. I usually run with the tow haul on and around 65 on the interstate.
Sent from my HTC0P3P7 using Tapatalk
Just towed the combination over to the Oregon coast for vacation. Overall trip mileage while towing was 9.14. Kept my cruise set to 68 on the interstate.
1 - 20 of 20 Posts
