so far my truck runs fine no problems with the engine. I am just wondering How will I know if I have the problem and is there any thin we can do to prevent it from happening?
Do It In A Van
Some have reported pinging and unexplained oil loss. My '94 Ram Van was losing oil, but I had no puddles or blue smoke. I looked down inside my intake manifold with a flashlight and saw where the oil was going. Rather than the "normal" amout of residue (from the PVC system), I saw puddling. It must have been burning it off slowly because like I said, no blue smoke.
The cause is well, quite frankly, a crappy gasket from the factory. I pulled the intake and replaced the gaskets with Fel-Pro. The plenum gasket from FP is steel embossed so it won't blow out again.
As far as preventing it? I don't know if that's possible. It may never happen to your engine.
GROUNDED
the steel gasket is the problem, it expands and contracts differently then te aluminum manifold and causes cracking, best gasket is a similar material such as an aluminum panel.
Where's the aluminum gasket available at?
Where is the modification to the intake manifold I have read about? What purpose does it serve?
The Green Machine
dodgerulessa said:
is there any thing we can do to prevent it from happening?
The only absolute way to prevent it from happening is to replace the stock kegger manifold with an M1 - they don't have that setup.
Hughesengines and APS Precision both make an aluminum replacement plate.
If you're referring to the kegger modification, check HERE
