1 - 2 of 2 Posts
so i was driving home last night, coming to a stop light and i noticed a faint vibration in the engine as i began to slow down. once stopped the RPM's were hovering around 200-300. there was a very noticeable vibration in the engine and the CEL was flashing. I had been experiencing some stalling issues in the past so i dropped it in N and gave it a few shots of gas to keep it running. once the light turned green i got it off the road in a parking lot, checked the fluid levels(which were fine) and turned it off. it fired up right away and has been running fine ever since, the CEL went out right away and hasn't come back on. I have since put about a 100 k/m on it and smooth sailing. I was thinking it was a miss fire or something like that, bad gas maybe?? anyone experienced anything like this with the 04 5.7's. oh and i had about a 1/2 a tank of gas at the time.
thanks, jason
I would check your throttle body and make sure it is clean.
Could also be your battery, is it still the original one you have in there?
1 - 2 of 2 Posts
