OK guys...I have my motor performing the weay I want it to, but now it is time to fine tune the suspension to put the power to the ground. I have the mods and power to run 1.8 60' times on every pass, but I am just not. My back end does not squat at all with the traction bars preloaded and the front barely rises even with 90/10 drag shocks. So I took off the traction bars last night and holy crap...my truck lifts like a dream..ON THE DRIVERS SIDE. The truck twists so bad now on launch that it feels like the front drivers side tire is coming of the ground and the passenger side isnt lifting at all. So here are my ideas on how to fix this.
1. Put the traction bars back on, but leave about 2" space between the snubber and leafs on the drivers side and only about 3/4" space on the passenger side. This will allow the drivers side to drop more than the passenger side causing the front drivers side not to lift so much higher than the passenger side.
2. Add rear spring clamps to the passenger side only. This would stiffen up the passenger side rear causing it not to drop so much on takeoff and therefore not allowing the front drivers side to lift so much.
Now what do you guys think about this?? I need to get the front end to lift evenly so that I have both rear tires planted flat on the ground.
