1 - 11 of 11 Posts
I'm looking to piece together a 9" or higher lift for my truck. I'm getting the 4.56 gears, and want to run at least 37's.
Was hoping for some help on what I need to look for. Truck's in the sig.
Thanks
if you want a 9+ all suspension lift you need to give a call to fullthrottle or whiplash, i have a whiplash 10" kit with 36x14.50 on a 16.5x10 wheel, i love the whiplash kit, i had no problems with it, oh yeah i have the 4.7L also.
you can get a 6 inch suspension lift, 3 inch body lift for 9" and then crank your torsion bars about 1-2 inches. you could get the whiplash and full throttle lift kit, they are pricey, but i dont personally know anyone who runs them and i personally wouldnt go any higher then 6 inches on an IFS suspension wise. you could probably be able to clear 38s quite easily with 9 inches of lift
I'm Not A Post Whore! :(
you'd have to have a killer offset and a skinnier wheel on a 1500 I think
I have a true 6" suspension 3" body and I barely clear 38's, and 39.5's rub
now, you could possibly do a 6" suspension, torsion bar keys, add-a-leaf and a body lift for 11-12" of lift, but not sure if it'd all work out that way
I don't want any body lift. All suspension. Thanks for the advice guys. Whats a good road tire thats a 37 or higher?
Thanks
goodyear wrangler MTR
I forgot to mention I'd like to keep my OEM 20" rims. I don't see where those Goodyear wrangler MTRs have them in a 20"?
Thanks
and Nitto Terra Grapplers 355 60 20
which is a 37x14.00r20
Dude get a skyjacker 6" suspension lift, then get some torsion keys, and add bigger blocks in the rear, and you'll have about 8" of lift.
you'll ripe your boots, because the diff isn't dropped down 6", its only dropped like 5 maybe 5 1/4", so if you crank it, it would only got up to 7" without pushing it to the limit. im telling you if you want a 10" kit its like $2,200 for a whiplash or a fts lift kit.
1 - 11 of 11 Posts
