I have a 96 dodge Ram 4X4 and the 4 wheel drive will not engage because the green and gray vacuum lines burned up during a fire caused by a transmission leak. I have rebuilt everything from the fire and the only thing that does not work is the 4 wheel drive. The transfer case shifts fine but the vacuum motor shift assembly will not engage. For some reason, I can not find where the green hose, which comes from the transfer case, plugs into on the other end at the engine. I have looked with a mirror and flashlight and can not find any connection points. The gray hose from the transfer case also burned up, but I found the other end. Does anybody have a clue where the other end of the green hose goes? Any help would be appreciated.
