ACE
i have a 99 1500 with auto. 4x4. i get a vacum type sound from behind the dash i think and i dont know what it could be. anyone have any suggestions?
tom
vacuum line or door actuator for your A/C... figure out what's not working... defrost door, hot/cold temp adjustment, etc... if you have a cracked dash id check the defrost door first...
ACE
how do you check the defrost door? do i have to pull the dash? the heat and a/c are working. there are just not very powerful. Ican barely feel them on low.
pull out the radio. pull the heater vent controle and look. there are diaphrams on the hvac doors for every dial placement. possibly behind the glove box too. i removed my dash for a heater core and familurized with this sytem. either a line leakes or the controle or one of the door diaphrams seeps. youll need a flash light and practice your upside-down yoga, its not easy. through the radio and glove box should be enough room for your arms
